9
This discussion topic has been answered Discussion topic: Sky Remote & TV Controls
This message was authored by: Thevoid
Hi, my sky remote used to turn the TV on and off, however I've forced a manual update for Sky and it's made me reset certain settings. I've paired the remote by Bluetooth but now I can't get the remote to turn the TV on and off liked it used to. Even when trying in the settings, it won't recognise my TV at all.
I have a Sony soundbar connected and the remote can control the volume for that by default (without even pairing the remote), but when that's unplugged and I try and get the sky remote to control my TV, it refuses.
Am I missing something? Thanks
Avatar for Thevoid
Level 3 icon
This message was authored by: Thevoid Answer
Re: Sky Remote & TV Controls
I've sorted it now. Just kept trying and it eventually worked. Thanks.
Hi @Thevoid, what do you mean you forced a manual update?
Have you tried restating Sky Stream and then try to find your TV model again?
Also is HDMI Control enabled in settings?
Avatar for Thevoid
Level 3 icon
I held the power button down on the box and plugged it in which forces a system update.
I've got HDMI turned on in the settings and tried restarting and linking the remote to my TV again but no luck. Sky can't find my TV.
First repower your TV.
On your Sky puck remote:
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue.
Follow the on screen instructions to connect your TV.
Unless you were instructed by Sky to do that, I wouldn't advise doing things like that in future.
Try the advice from Lettice and hopefully you can get it working. If not,try going through similar Sony TVs because one of those might work even if your specific model isn't listed.
Avatar for Thevoid
Level 3 icon
That's what I've said isn't working though. Sky can't find my tv
Avatar for Thevoid
Level 3 icon
I don't understand how it used to work and had previously found the TV, but now can't though.
That is weird. Can you share your TV model number please?
Avatar for Thevoid
Level 3 icon
@Thevoid Good stuff, glad you got it sorted
