4
This discussion topic has been answered Discussion topic: Sky Q remote on Sky stream?
This message was authored by: tellybug
Hi!
I'm currently without a remote for my stream puck but I had a Sky Q remote laying around and a Google search which linked to this forum told me that they do work in IR mode, however when I try to control the puck it only responds to the power and home buttons so the remote is definitely working and the puck is understanding some of the commands, the remote is an ECO60 model which is strictly infrared so it isn't in Bluetooth mode.
Is there a way to get it paired or has Sky patched it recently as those posts are quite a few years old, I'm fairly certain I'm on the latest version but I can't check without a working remote. 🙃
Cheers
This message was authored by: Skull+Treaty Answer
Re: Sky Q remote on Sky stream?
@tellybug
According to this link, you may be able to get a new remote if your still in warranty
Get in touch
Need a new Sky Glass or Stream remote? If it's in warranty, we can send you a new one.
Not sure when your warranty runs out or need more info? See Sky Glass and Sky Stream warranty.
A warranty. Just in case.
Each warranty starts from the date the item is delivered and covers your Sky remote too.
  • Sky Glass TV (new or refurbished): 2-year warranty.
  • Sky Glass speaker fascia: 6-month warranty. Please note this doesn't apply to Sky Glass Gen 2.
  • Sky Glass Wall Mount: 1 year warranty.
  • Sky Stream puck:
    • Unlimited warranty* if you ordered after 23 February 2023.
    • 1-year warranty if you ordered before 23 February 2023.
@tellybug Sky Q remotes did work with Strea,/Glass when they were first launched but it wasn't long before that compatibility was withdrawn, so the information you've found is somewhat out of date, I'm afraid.
Have you tried or seen the Sky remote app?
https://www.sky.com/help/articles/sky-remote-app
Avatar for tellybug
Gotcha, I had a sneaking suspicion since only two buttons on the Q remote worked. As lettice mentioned I'll give the remote app a go and hopefully that'll do the job until I can source a replacement.
Kind of a shame that they did indeed patch it out, since I'd imagine with everyone upgrading from Q there'll be a lot of spare remotes lying around that could've served a new purpose as a spare or second remote.
Thank you for the information though, much appreciated! 😊
@tellybug
Get in touch
  • Sky Stream puck:
Answered - Go to Answer
