Discussion topic: Sky Puk Doesn’t work
This message was authored by: Terrie82
Hello I've had a sky puk for a couple of weeks now and it doesn't work. I have had no TV since getting this. It works for 10 mins then goes off, either black screen " please wait while your programme is loading" or " there is a technical issue please try again later" or it just freezes. I have tried all trouble shooting ideas, I have plugged the puk directly into the router. I have tried disconnecting other things from the router. I have tried everything. It doesn't work. So unless any one has any ideas on getting this thing working is there a way I can swap it for SKY Q? Thank you
This message was authored by: Padam_Padam
Re: Sky Puk Doesn’t work
What broadband speed is being received by the puck? Run the network check from the puck's Netflix app, under the get help menu. This will tell you if sufficient speed is being received.
hi @Terrie82
This sounds like it could be your broadband speed. Who is your ISP and what speeds do you recieve? When you plugged it in via ethernet, did you turn WiFi off in the network settings on the puck?
In order to go to Sky Q, you will need to call Sky as we are fellow subscribers, however you cannot have two Sky TV services at an address at the same time. They will need to terminate you stream account and set up a Q account and arrange an install appointment, you will be without service during this time.
MikeAlanR
