Discussion topic: Technical issue
Message posted on 02 Apr 2024 05:40 PM
Technical issue
sky comes on to the normal Home Screen, but the remote won't let me scroll up or down or press anything. I tried changing the batteries and recalibrating the controller but neither did anything and after a brief time sky goes off and it just says no input
Message posted on 02 Apr 2024 05:53 PM
Re: Technical issue
Some things to try
reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
The last option to try and fix the remote is to remove the batteries for several hours and then put them back in before trying a reset of the remote.
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
