This discussion topic has been answered Discussion topic: Sky Puck taking 5 minutes and 20 seconds to start, why?
Message posted on 18 Jun 2024 08:14 AM
Message posted on 18 Jun 2024 03:43 PM
@Alexiow Your bootup time does seem excessive. As a test, I just turned mine off at the plug and switched it on again and it took 1 minute 20 seconds to come back to life again.
Personally I just turn the Stream puck and TV off with the remote and it boots up in the morning in around 10 - 15 seconds. Try that tonight and see how it goes in the morning.
Message posted on 18 Jun 2024 08:25 AM
Re: Sky Puck taking 5 minutes and 20 seconds to start, why?
Either
Try a power reset of the puck, by removing the power or switching off at the socket for at least 30 seconds
Or
On the puck
Go to Settings>System Management>Resets and Updates>Restart Device
Press Select.
This will do a restart of the puck (this is a new function with the latest Q28 fiirmware build that has just gone out to all customers this last month).
It will take a few minutes to perform this restart before the puck is available to use again.
Message posted on 18 Jun 2024 11:50 AM
Thank you for this information. I've done the update to 28 and I'll see if it's done the job tomorrow morning after being turned off all night. I appreciate your input thank you.
Message posted on 18 Jun 2024 01:29 PM
@Alexiow In addition to the advise given by @lettice I would also go into the setting menu and make sure that Networked Standby Mode is turned ON. This stops the puck losing the network connection when it is in standby.
To find the relevant toggle switch go to Settings > Start up and standby menu. Whilst there I would also turn off the overnight power saving.
Message posted on 18 Jun 2024 02:42 PM
The Network standby mode was already on but I did turn the overnight power saving off. I've just been out for over an hour and I always turn the power off things like the sky puck, but when I came home and turned it on it still took 3 minutes and 20 seconds to boot up? Although 2 minutes faster than last time, surely no one's else's puck is taking sooo long?
So far I'm seriously NOT impressed with this Sky puck!
Message posted on 19 Jun 2024 04:01 PM
Yep that has seemed to have sorted the long delay out. Thanks guys for all your help.
