Discussion topic: Sky Puck box will not start up properly
Message posted on 05 May 2025 06:49 PM
I have been havig problems wwith my Sky Puck streaming device. It wither freezes while I am watching something. Or I get a message after the programme stops and it says, "Pleasae wait while your programme loads". I also get problems when it refuses to start up properly. This happens very frequently.
Message posted on 05 May 2025 08:21 PM
Re: Sky Puck box will not start up properly
You are either not using a fast enough broadband speed, or your WiFi connection is unreliable or both.
try a hard wired Ethernet connection.
also try moving the puck away from its current position
Message posted on 05 May 2025 10:17 PM
@JohnTheTenor wrote:I have been havig problems wwith my Sky Puck streaming device. It wither freezes while I am watching something. Or I get a message after the programme stops and it says, "Pleasae wait while your programme loads". I also get problems when it refuses to start up properly. This happens very frequently.
This is a bug that some people are experiencing and others not, if you can try and persevere with it until the next software update comes out and hopefully that will resolve it @JohnTheTenor
