This discussion topic has been answered Discussion topic: Sky Puck and Projector
Message posted on 01 Sep 2025 02:00 PM
I have connected my sky puck to a new projector
The sky menu displays correctly
When I select a programme the box in the bottom right is black but I have sound (and I still see the sky menu)
When I select the programme the whole screen is black
if I go into Netflix I have the same problem but I do see subtitles
any thoughts anyone please?
Message posted on 01 Sep 2025 03:34 PM
WiFi connection is only needed for either an online firmware update or to stream media from a home NAS drive, mirror a smartphone or similar. WiFi is not needed for to use an HDMI connected device though.
If a manufacturer make firmware updates user updatable & provides instructions via their user manuals, they're generally quite safe to do. I entirely understand your reluctance to try though if (and it s a big if) anything should go wrong.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
Message posted on 01 Sep 2025 02:10 PM
Re: Sky Puck and Projector
And when I select the programme and the whole screen is black I do have sound
Message posted on 01 Sep 2025 02:13 PM
@DaveE4 Presumably you have your Sky Stream puck hooke3d directly up to your projector via HDMI and not through another device?
If your projector is capable of handling UHD/4K, try going into Settings > Picture and sound > Picture and setting your Puck to output just 4K without HDR. Does that work ok? if so, your projector might be having difficulties handling one or more of the HDR formats (Sky use HLG for all of their content, Netflix use Dolby Vision and HDR10.)
If HDR does prove to be the problem, does your projector have the ability to update its firmware, either via a network connection or a USB drive?
Message posted on 01 Sep 2025 02:20 PM
Thanks!
In 'picture' I don't think I have that option?
I just see
- picture resolution (with 1080p etc)
- default screening format (with auto, uhd and hd)
- judder reduction for TV apps
Message posted on 01 Sep 2025 02:22 PM
Yes, it's connected by HDMI.
Message posted on 01 Sep 2025 02:39 PM
I'm not at home right at this moment to check the exact options/settings on my own Sky Stream puck. In the meanwhile, give the following a try....
From sky,com > help > articles > setting up ultra HD
- Press Home on your Sky remote.
- Go to the bottom and select Settings.
- Select Picture and sound, then highlight Picture format.
- Choose 2160p (UHD).
- Select 10-bit so you can watch in HDR too. Not sure if your TV supports 10-bit? Select Find it for me. It if can it will select 10-bit, if not it'll select 8-bit and you won't be able to watch in HDR.
- It'll say 'Do you want to save the changes?'. Select Confirm.
Didn't see the 'Do you want to save the changes?' message? Wait for the main screen to return, select Continue and try 8-bit. You should see the message this time. Select Confirm.
Message posted on 01 Sep 2025 02:52 PM
Thanks @CoffeeDrinker
tried that and got 'this input on your TV (projector) doesn't support untra HD'
I do have a HDCP2.2. HDMI
Sounds like the new projector is the issue?
Message posted on 01 Sep 2025 02:54 PM
@DaveE4 wrote:Thanks @CoffeeDrinker
Possibly - what make & model of projector do you have?
Message posted on 01 Sep 2025 02:59 PM
It's a Philips NeoPix 130C Smart
Message posted on 01 Sep 2025 03:15 PM
Looking at the PDF manual for your projector at https://www.documents.philips.com/assets/20240607/9d5e971531874b9ab652b1880029a48a.pdf
On page 26 there is a section on updating your projector's firmware online. Assuming you have your projector on your home WiFi, it might be worth checking if there is an update available. On regular TVs, such firmware updates often have fixes for HDMI device handshaking for mutually supported formats.
Otherwise the maxmum supported resolution for HDMI input looks to be 1080x1920 (page 27) and doesn't look to support HDR. It might be worth manually setting your Sky Puck's picture output to 1080x1920 HD, rather than one of the UHD resolutions & formats.
Message posted on 01 Sep 2025 03:25 PM
Projector is brand new so I'm a bit reluctant to update firmware etc and might just take it back to the store
it is not connected to home WIFI as I didn't think I needed to with the HDMI connection to the Sky Puck (hope that's not the issue!)
Message posted on 01 Sep 2025 03:44 PM
