Discussion topic: Sky Glass Installation
This message was authored by: MrsTitmus
we have had our Sky Glass for just over a year and it's always tilted slightly forward from the top, is this normal?
Avatar for MrsTitmus
Level 2 icon
Re: Sky Glass Installation
I should also say it's sat on a cabinet on the stand.
@MrsTitmus Provided the TV is fitted to the stand correctly and is completely flush at the back it shouldn't be tilted.  Assuming the stand is fitted correctly I would then check your cabinet with a spirit level to ensure the surface the TV is sitting on is level.  I can't think of any other reason your Glass would be tilting.
This message was authored by: Jones_The_Cat
An unstable Sky Glass unit, if it were to fall forward, would be very dangerous. Not just due to the inevitable damage to the screen, but the weight of these things could cause serious injury to any human or pet in the way.
