Discussion topic: Signal
This message was authored by: Jess20241
Signal
Telly not loading, moutha don't match up with the words and crap signal. Need an engineer.
This message was authored by: Mister_Dalek
Re: Signal
There are no Sky Stream engineers. You need to troubleshoot your broadband signal yourself. Try connecting via ethernet and turn WiFi off on the puck settings.
Avatar for Jess20241
Re: Signal
I can't connect Ethernet because the guy put the box in bedroom upstairs and my TVs downstairs.
Re: Signal
In that case you could try either powerline adaptors to help or purchasing a more powerful router to help boost the WiFi signal.
Worth making sure your router currently is in the best postmitiom, so it should be out in the open and not low on the floor, that may help improve its strength.
Re: Signal
How do I go about getting one of those can I purchase through sky?
Re: Signal
Amazon - you can get the more basic ones which are around £40, as the ethernet port on the stream puck is capped at 100 mbps.
