Discussion topic: SKY Stream Novice
Re: SKY Stream Novice
@MarkGoldsmith wrote:
@JER4 wrote:
@TimmyBGood
Thanks for replying. I accept what you say but, for the new technologically challenged user like me, I still think a short instruction booklet, either printed or with an online reference, would be helpful.
I've always thought a little piece of paper in the box with the URL to the online Sky help documentation or the official Sky Youtube channel would be extremely useful for customers.
Isn't that better supplied with the order confirmation ... so it can be read before Sky Stream device delivery😉
@JER4 wrote:
@TimmyBGood
I wouldn't have thought so. Most customers seem unlikely to read the entire contents of long emails, and i think typically users don't care about looking at instructions until after the device has been delivered 😀
@JER4 wrote:
@TimmyBGood
Not if the information is supplied at the start of the order confirmation🤔
Avatar for JER4
This message was authored by: JER4
@Exiled-in -HH
Ha, Ha!!
I borrowed a 10 year old.
This message was authored by: best+of+the+best
@JER4 wrote:
@TimmyBGood
Not if the information is supplied at the st isart of the order confirmation🤔
Actually it is @Exiled-in-HH google search How to set up Sky Stream
https://www.sky.com/help/articles/setting-up-sky-stream
Simple
@JER4 wrote:
@TimmyBGood
Simple
So a scrap of paper is not required ... that's the link that would be supplied in the order confirmation😉
Avatar for JER4
@Exiled-in-HH
So looks like we have a consensus.
A note in the package directing  new subscribers to an internet location where simple setup and use instructions can be found would be useful. I'm sure Mr Murdoch could afford this. Wonder if SKY will think about actioning the suggestion.
I'm sure Comcast would happy for a "Mr Murdoch" to pay for a pointless scrap of paper😉
@JER4 wrote:
@Exiled-in-HH
I'm afriad you're well behind the times, Murdoch has had nothing to do with Sky for quitre a long time, Sky are owned by Comcast in the USA.
The Murdoch empire has had nothing to do with Sky, since Sky was owned and controlled by Comcast in the Autumn of 2018.
