Discussion topic: SKY STREAM - New software build QS021.005.00P caused new audio sync issue
This message was authored by Tommyd1 This message was authored by: Tommyd1
Re: SKY STREAM - New software build QS021.005.00P caused new audio sync issue
Question a kit the hd fury!
My TV is earc but the soundbar is regular arc.
Is there any point in me getting this or does it only work with non earc TVs and arc soundbar?
This message was authored by Peter682 This message was authored by: Peter682
Similar problem to most of you,I changed the audio setting on the puck from auto to PCM stereo, works fine now,
This message was authored by Mikeabc1 This message was authored by: Mikeabc1
Same here. Had been on auto but back to PCM stereo 👍
This message was authored by LS3Capri This message was authored by: LS3Capri
That's fine for people with 2ch audio, but a lot of people run Dolby systems so only masks a problem.
This message was authored by Fothergill1 This message was authored by: Fothergill1
@LS3Capri (and others).  There is a more up to date threat on the new lip sync issue resulting from the recent software update  at the following link which may be of interest 😀.  QS025 Lip Sync Issue
If my post has solved your issue please mark as an "Answer"
