Discussion topic: Replacement puck
This message was authored by: Stonechat
Replacement puck
I've been offered a replacement puck. On delivery I am to hand the old one back to the courier. Can anyone tell me if I get a new remote with the replacement puck or should I keep the original? Thank you.
Re: Replacement puck
Hi @Stonechat
You should get a full boxed puck with remote, power cable and hdmi.
MikeAlanR
Avatar for Stonechat
Level 2 icon
Thank you. That's what I was hoping because I've repacked everything in the original packaging.
Level 2 icon
Replacement puck what you get
I have been given a replacement puck.
Sky ask that you pack up the old puck to be exchanged at the door by DPD courier.
I was concerned about what to pack as it was un-clear. So I ended up keeping the remote and leads and just packed up the puck (advised by sky messaging)
For those who are in the same boat here is what you receive as replacement. New puck, power lead, hdmi lead and remote
control. So basically a brand new package.
Hope this helps anyone getting a replacement puck. I would advise that you still check with customer service, Sky messaging or chat.
Re: Replacement puck what you get
@Stonechat
You were advised of this in this thread: https://helpforum.sky.com/t5/Sky-Stream/Replacement-puck/td-p/4947681
Not returning everything asked isn't recommended as you may be charged a non return fee. As per info here: https://www.sky.com/help/articles/charges-for-not-returning-sky-stream-puck
You'll need to return any:
Sky-owned Sky Stream pucks
Remotes
Cables
MikeAlanR
Level 2 icon
Hello
I spoke to an advisor before hand who advised me to only return the puck.
If there is a problem I shall explain and return the other items. Sorted 🙂
@Stonechat  I have merged your post to your previous thread for continuity, a new thread isn't required.
This message was authored by: Haze6
I am finding it difficult to order a replacement Puck as I've misplaced it during my recent house move (will probably find it in a few months time!) Anyway, not having much luck talking to the BOT to try and order a new one. Can you help?
Hi @Haze6
We are fellow customers you will need to call Sky.
MikeAlanR
