1
This discussion topic has been answered Discussion topic: Removal of Sky Stream batteries without having to break their plastic holder.
This message was authored by: Alan278
Opened the Sky Remote to access the batteries. Had to remove the circuit board and button carriage. Batteries are held in black plastic cradle and impossible to remove without breaking the cradle.
This message was authored by: mikealanr Answer
Re: Removal of Sky Stream batteries without having to break their plastic holder.
Hi @Alan278
That doesn't sound right at all. All my sky glass and stream remotes you slide the back cover off and lift out the batteries.
See: https://www.sky.com/help/articles/remote-control-help-sky-glass
Are you able to post some pictures? Have you unscrewed anything?
MikeAlanR
Hi @Alan278
MikeAlanR
