This discussion topic has been answered Discussion topic: Remote problem
Message posted on 02 Mar 2026 08:05 PM
Had new remote for stream, but volume will not work!!! Anyone any ideas
Message posted on 02 Mar 2026 08:31 PM
Hi @RMB4079
You will need to give some more information such as the make and model of the TV you are trying to control.
The general advice would be to press 1 & 3 together for a few seconds and follow the instructions to re set up your remote. Try selecting the manufacturer and then step through the codes until you find one that works.
MikeAlanR
Hi @RMB4079
MikeAlanR
