Discussion topic: Remote control
This message was authored by: StuPot65
Remote control
Brand new remote failing to work randomly.
slightest tap causes this.
replaced batteries.
its as if they are not sitting tightly.
could a replacement remote be the fix?
Re: Remote control
@StuPot65  I would be inclined to request a replacement remote at the following link:  Streaming TV replacement remote
In the meantime you could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again.
If you have one available you can use a Sky Q remote while you wait for a replacement.
