16
This discussion topic has been answered Discussion topic: Remote control set up code for TCL FIRE Tv
This message was authored by: David7747
Does anyone know the SKY remote control set up code for Model TCL 32SF540K
Avatar for David7747
This message was authored by: David7747 Answer
Re: Remote control set up code for TCL FIRE Tv
Sorry to hear that, all I did was enter JVC in the list of tv's and kept trying each one until the sound alters, and it worked on the 19th setting, whereby I can now alter stations, switch off/on etc
Some have found selecting JVC works, but try a few codes listed under Toshiba, some say it's been about 18-20 attempts  in the list
Others have said Vestel and Toshiba has helped also.
This message was authored by: NicD81
This is not working for me. Just bought the same tv 32SF540K. No luck in getting the volume to work with sky stream remote.
Hi David,
Thanks for the reply. I have tried JVC a few times and tried switching the volume for each number under "Find it for me" and it still doesn't work. Should I try switching the power button instead? Changing the channels work, but power on/off and volume does not. I really really don't want to have to use 2 remotes. Am considering returning the TV to Amazon if this can't be fixed.  Thanks again!
Nic
Let me know what happens
This message was authored by: JoolsJ
I'd like to know as well
This message was authored by: JerryUK57
On TCL 50PF650K fire TV with Sky+HD rev10, code 0584 worked for me (power on/off and volume)
How do you enter a code and not do it by TV brand setup?
This message was authored by: Solfer
As far as I know, it's not possible to enter tv codes on sky Stream remote setup.
I'm in the same boat with this TV, none of the other brands work for me either 🙄
This message was authored by: mbird21
If you search for TCL in brands, and its around attempt 3/4 you should be able to use the volume control.
Hope that helps
Thanks but I'd already tried that a number of times, doesn't work for me.. 🙄
This message was authored by: Hunter2660
Just to add to this. I recently purchased Amazon's 75" omni Fire TV, and I eventually found the code under JVC, number 17 on the list. Controls the volume perfectly, not particually worried about putting the set into standby. I just ask Alexa to turn off the tv, which turns off the Stream box at the same time. 😎
This message was authored by: Mickusher
  • Thank you for sharing your code after trying 40 different codes yours worked perfectly....great help and thank you
  • 0584
The 8th or 9th Toshiba code now works. Try it everyone!
Answered - Go to Answer
