Discussion topic: Re: Technical fault
This message was authored by: Natu55
Re: Technical fault
My sky tv apps not working
Avatar for Natu55
Re: Technical fault
Sky little box
Avatar for Natu55
Re: Technical fault
Can't receive sky channels
Re: Technical fault
Have you tried a reboot?
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
