Discussion topic: Technical fault channels won't change
This message was authored by: N7jaz
Message posted on 10 Sep 2025 09:27 PM
Lately the sky stream box randomly stops allowing us to change channel. Nothing wrong with remote but box itself as it states technical fault try later. Tried turning off (not reboot) but hasnt been successful. Will work after reboot but this is happening every week and each week a reboot is ridiculous.
Find out more
Message posted on 10 Sep 2025 09:30 PM
Re: Technical fault channels won't change
@N7jaz On the stream puck open the Netflix app, go to get help, run connection test. What speed is being reported?
