Discussion topic: Puk stop working when using microwave
This message was authored by rwp1 This message was authored by: rwp1
Puk stop working when using microwave On all channels an apps can it be resolved
This message was authored by mikealanr This message was authored by: mikealanr
Re: Puk stop working when using microwave
@rwp1
That would suggest your microwave is interfering with your WiFi. You don't say who your ISP isp is but your options are to either move your puck, boost the signal with repeaters or homeplugs or connect using ethernet cable.
Is the WiFi weak / marginal ?
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
rwp1
My isp is bt
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
@mikealanr wrote:
@rwp1
MikeAlanR
Those options listed above by @mikealanr are the main recommended ones - i suppose you could also try replacing the microwave and see if that helps as another option but personally i'd recommend connecitng via ethernet cables and not Wifi in order to stop this interference.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
@rwp1
If the microwave is leaking enough RF to knock out local WiFi, I'd strongly suggest not using it any more.
Could also be interference from a failing electrical motor though, I guess.
This message was authored by Nigelb1972 This message was authored by: Nigelb1972
@rwp1 you really need to stop using your microwave and replace it as it should not be leaking enough RF to interfere with your WiFi. It has the potential to be hazardous to your health.
