Discussion topic: Poor picture with live tv pixels freezing
This message was authored by: Welder23
Live tv freezing and pixels on the screen.
This message was authored by: Jporch316
Re: Poor picture with live tv pixels freezing
Try a reboot by pulling the plug for a few minutes
if the issue still persists then it maybe a poor wifi or slow internet issue
you can check the speed arriving at your device by opening the native Netflix app - scrolling down to get help and running the network check
you need ideally over 30mbs consistently to run stream
Avatar for Welder23
Thanks for your reply I will try that when I get home. Regards Nigel
