5
This discussion topic has been answered Discussion topic: Puck white light flashing
This message was authored by: Super+Anthony
White light flashing underneath the puck for around 10 minutes so far and nothing turning on. I did briefly get Sky logo on the blackscreen. It then stops so I try to turn on using the remote. Then the flashing starts again and I try to turn on, and it just carries on flashing.
Any idea to fix please
(Please Note: I am Neurodivergent )
This message was authored by: lettice Answer
Re: Puck white light flashing
Have a read of this Sky help article, namely running the recovery procedure on step 4
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-strea...
Avatar for Super+Anthony
Level 11 icon
I just unplugged the puck and put the it back on by pressing the button on the bottom of the puck till the logo came on and its now at the blue screen and Please Wait. Thanks @lettice. Pro. Just looked at the settings and its updated the UI version to 3.161.1 so it looks like it froze on an update? It was on an earlier one at lunch time
Glad to hear you are up and running again.
Level 11 icon
Appreciate your kind words @lettice
This message was authored by: JazTheTim
I have the exact same issue. The restart failed.
the recovery process fixed it.
thanks @lettice  for the link.
