Discussion topic: Puck reset not working (white screen)
Message posted on 05 Jul 2025 05:24 PM
Hi, My Sky Stream has just started giving a white screen (like terestrial TV with no coax). Tried repeated hard resets without success.
This is my second puck as Sky said it was a hardware problem with the first (same issue). The old puck did seem to correct itself after a day or so which suggests it is not a hardware issue.
Any experience of this please? (I am not a Sky Glass customer)
Message posted on 05 Jul 2025 09:43 PM
Re: Puck reset not working (white screen)
@Chris569 Are you able to watch anything at all or is it a white screen on everything? Also how are you connected to your tv, is it over Wi-Fi or via an Ethernet cable?
Message posted on 06 Jul 2025 11:12 PM
White screen on everything. Switching the router off had no impact so suggesting the puck was losing wi-fi connection. I then tried another hard reboot of the puck and after the s/w update had completed, pressed the WPS on the router and it seems to have solved it (for now). Sky were adamant it was a h/ware issue, clearly not the case. Thanks for the response.
