Discussion topic: Puck problem
This message was authored by: Joby1
Puck problem
Hi my puck has started to not come on with the remote. If I press button on puck it comes on and I can then use the remote to access everything. Once on I can turn on and off with the remote. If I then turn it off for 30 minutes I have the same problem again. I cant see its a remote fault as its fine once its on. Not sure what to do. Anyone else had this problem?
Re: Puck problem
Is HDMI control enabled in settings > start up?
Avatar for Joby1
Re: Puck problem
Yes it is. Its worked fine for nearly 2 years just having problem this last week
Re: Puck problem
Very odd. Have you tried restarting the puck?
  1. Go to Settings
  2. System management
  3. Resets & updates
  4. Restart device
This message was authored by: Jporch316
Re: Puck problem
@Joby1
I would try pulling the plug on both the Tv and the puck for a few minutes
Avatar for Joby1
Re: Puck problem
Hi Andrew I've just done what you said  it worked then I tried it later and it's not working again.
Hi Jporch I  have done this it works straightaway but not after a break
V bizarre
Re: Puck problem
@Joby1
Try resetting the sky remote
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Avatar for Joby1
Re: Puck problem
Hi yes I did that one too
Re: Puck problem
@Joby1
I have  escalated your luck to the online sky community support team
please look out for an invitation to chat with them
Avatar for Joby1
Re: Puck problem
Fab thanks for your help
This message was authored by: Addie15
Re: Puck problem
Hi there! Thank you for escalating this. We have sent an invite to @Joby1.
