Discussion topic: Puck keeps freezing then trying to reboot
Message posted on 03 Jun 2026 06:50 PM
Message posted on 03 Jun 2026 07:16 PM
Re: Puck keeps freezing then trying to reboot
Provided you have a stable WiFi connection the puck shouldn't really have issues, yes they can be a little lagging at times but shouldn't be anything major.
You say reset is that restart from the menu? Reset is a last resort really.
if you haven't done it unplug the puck from the main and power off your router this will clear any cache. Switch the router on and once reconnected power up the puck and connect via your WiFi.
This should clear any problems if not you may have a puck that needs replacing.
Message posted on 03 Jun 2026 08:18 PM
I did all that and it's happened again
How do I get a new puck?
Message posted on 03 Jun 2026 08:46 PM
You'll have to call the Sky Centre go through to tech support.
Message posted on 03 Jun 2026 11:21 PM
@Dhles wrote:I did all that and it's happened again
My uncle had just this problem the other week. I went through everything knowing what I was dong having my own puck for a few years. We had to go through all the usual help on the phone with Sky before they came to the same conclusion that somethings wrong with the puck and arranged to collect the old one and send out a replacement. The replacement was perfectly fine and worked as expected.
Out of interest what software Build Number is it showing it has on it in settings > System Management
My puck was o.n QS037..... at the time we had issues with his faulty puck and that one had QS038... on it. That was the only difference I noticed at the time. Today my pucks updated and gone from QS037.. to QS040.024.00P. It may have just been faulty hardware though but just makes me wonder.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS040.024.00P; UI Version: 3.214.2 | Sky Broadband Superfast
