Discussion topic: Puck issues
This message was authored by: Numan2
Puck issues
I've had my puck for over a year and I'm happy with stream. But recently I have to restart puck and refresh apps everyday otherwise steam will not work properly?
This message was authored by: Stephen+Mourton
Re: Puck issues
@Numan2   Has anything change recently.  If not connected via an Ethernet cable has any objects moved blocking line of sight to your puck or objects put near your puck or router etc?
Avatar for Numan2
Level 2 icon
Re: Puck issues
No nothing has changed.
Re: Puck issues
@Numan2   Thanks for confirming nothing has changed but despite that can you confirm if you are not connected via an Ethernet cable and if not if your router has a clear line of sight etc etc please?
Avatar for Numan2
Level 2 icon
Re: Puck issues
Router has a clear line of sight wireless connection. Nothing has changed the puck has always been in the same position as is my sky hub.
