Discussion topic: Puck freezing and loosing WiFi
Message posted on 06 Aug 2024 08:00 PM
Message posted on 06 Aug 2024 08:32 PM
Re: Puck freezing and loosing WiFi
@malcolmhales black or white router from Sky?
Message posted on 06 Aug 2024 09:02 PM
@malcolmhales How is the puck connected to your hub?
Have you run a speed test on the puck? Open netflix go to get help and run the connection test.
Any speed less than 20mbps for HD & 30mbps for UHD will cause an isue.
It sounds like this is more a wifi issue than a broadband issue so your post has been moved to the relevant section for Sky stream.
Message posted on 07 Aug 2024 05:40 AM
@Highlinder it's a white router!
Message posted on 07 Aug 2024 05:41 AM
@Highlinder is it worth running an ethernet cable between the router and puck?
Message posted on 07 Aug 2024 06:59 AM
@malcolmhales It would be, you would need to turn WiFi off in the pucks settings menu if you use ethernet, and restart the puck
Message posted on 07 Aug 2024 07:15 AM
Will that effect the household WiFi? I truly think there is a problem with it because sometimes my phone WiFi drops out as well. The puck problems are only on the BBC stations it seems.
Message posted on 07 Aug 2024 07:22 AM
@malcolmhales Stream pucks don't form part of a mesh unlike Sky Q boxes, there would be no effect on your existing WiFi signal.
