Discussion topic: Puck freezing and loosing WiFi
This message was authored by: malcolmhales
My streaming puck keeps freezing and the puck says it's lost the WiFi, but my phone says it's fine!
Re: Puck freezing and loosing WiFi
@malcolmhales  black or white router from Sky?
@malcolmhales  How is the puck connected to your hub?
Have you run a speed test on the puck?  Open netflix go to get help and run the connection test.
Any speed less than 20mbps for HD & 30mbps for UHD will cause an isue.
It sounds like this is more a wifi issue than a broadband issue so your post has been moved to the relevant section for Sky stream.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Avatar for malcolmhales
@Highlinder it's a white router!
@Highlinder is it worth running an ethernet cable between the router and puck?
@malcolmhales It would be, you would need to turn WiFi off in the pucks settings menu if you use ethernet, and restart the puck
@GD1
Will that effect the household WiFi? I truly think there is a problem with it because sometimes my phone WiFi drops out as well. The puck problems are only on the BBC stations it seems.
@malcolmhales  Stream pucks don't form part of a mesh unlike Sky Q boxes, there would be no effect on your existing WiFi signal.
