Discussion topic: Problems with sky stream channels 108 and 109
Message posted on 28 Aug 2024 06:34 AM
Any one else finding that channels 108 and 109 aren't working on sky stream..
Just getting "please wait for your channel to load followed by "there is a technical fault with this channel,please try again"
Message posted on 28 Aug 2024 07:06 AM
Re: Problems with sky stream channels 108 and 109
Both normal for me at 0705
Message posted on 28 Aug 2024 07:08 AM
Both channels working ok.
Mind Sky Max channel wanted a parental pin to watch.
Are you still seeing the issue?
Message posted on 28 Aug 2024 07:09 AM
Yep. Started working again at 07:00
Message posted on 28 Aug 2024 07:10 AM
Thanks . I think somehow it forgot to ask for pin so defaulted to technical fault
Message posted on 28 Aug 2024 07:11 AM - last edited: 28 Aug 2024 07:16 AM
You may have done so already.
But might be worth flagging to VR at that it was off at that time.
So they can check their logs of the available stream.
Message posted on 28 Aug 2024 07:12 AM
Can find the email address so posted in superusers
Message posted on 28 Aug 2024 07:19 AM
I edited my post above 😀
