Discussion topic: Problems with my sky puck
This message was authored by: Michaelahall
Hello I have been having problems with my sky puck loading anything apart from YouTube
Re: Problems with my sky puck
Have you checked your broadband connection? Tried rebooting the puck?
Find the speed your puck is actually receiving by opening the Netflix app, navigate to the get help menu and run a network check.
A Stream puck needs a constant and stable connection to Sky's servers to function. That speed needs to be a minumum of 25Mbps ideally.
Avatar for Michaelahall
Level 0 icon
I've checked all
of that and the connection is perfectly fine
I've checked all
Are you connected via WiFi or ethernet?
