Discussion topic: Prime stopping and starting.
This message was authored by: AJ1974
Prime will sometimes stop and start in the evening, no other apps seem to be affected. This only seems to happen on the main tv in the living room. Can a faulty puck cause this?
Re: Prime stopping and starting.
If you have not tried already.
Would suggest trying a restart of your Sky Stream box
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
Plus, performing an apps rerfresh;
  1. Press Home on your Sky remote, then highlight Settings.
  2. Press System management, then Resets and updates, and finally Refresh apps.
  3. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing. Note: An apps refresh can take up to 24 hours to complete.
You could also try a restart of your broadband router/hub.
Avatar for AJ1974
Thanks I will give that a try.
