Discussion topic: Power supply for sky stream
Message posted on 10 Feb 2025 08:57 PM
Message posted on 10 Feb 2025 09:07 PM
Re: Power supply for sky stream
@Jadem14 It needs a power supply and you should have been provided with one, you'll need to call Sky to resolve this.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 10 Feb 2025 09:09 PM
Message posted on 10 Feb 2025 10:45 PM - last edited: 10 Feb 2025 11:07 PM
Seems odd there is no power supply.
In the box, there should be the puck, remote, the plug in power block with its attached cable and an hdmi lead.
Are you certain, that you have not missed it in the compartmented box?
