Discussion topic: Please wait for programme to load
Message posted on 30 Mar 2024 09:38 PM
I've got this issue yet again it got stuck on homepage and rv listings and all the channels went off air for no reason Tried ringing sky they were closed tried a restart got it up and running and after that it went back to please wait for programme to load yet again playing up tonight the puck many thanks
Message posted on 30 Mar 2024 09:41 PM
							Re: Please wait for programme to load
Checking on Netflix speed test 35.39 mbps which it's showing now
Message posted on 30 Mar 2024 10:04 PM
The private community chat were very helpful they said if its happened again we will look in to why its happening broadband connection yeah that's correct they were quite helpful many thanks
Message posted on 31 Mar 2024 09:29 AM
I have had the same issue (400Mb connection only stream streaming) and even re-created the issue with Sky on the phone.
No fix - we just have to wait for Sky to fix their content delivery system or firmware to puck
Last night, it happened for a solid 10 minutes on all channels but a few.
Suggested fixes (which I have tried)
- Wired connection
- Sky DNS
- Replacement puck
Message posted on 31 Mar 2024 11:42 AM
Your not the only one then it comes up when flicking through most channels and black screen states please wait whilst we load your programme nothing happens technical issues please come back later but I switched the hub off and that same message came up please wait whilst we load your programme after switching off the hub so that is down to the hub oh well thanks for that info though
Message posted on 03 Sep 2024 07:25 PM
We get this fairly often and mostly when selecting "watch programme from start". We're on Hyperoptic fibre which is, as far as I believe, prone to issues with Sky (or vis-versa). No idea what the fix maybe except getting rid of Sky or Hyperoptic
Message posted on 03 Sep 2024 09:10 PM - last edited: 03 Sep 2024 09:12 PM
Same issue here too.
This is my second puck in 4 months.
Message posted on 29 Oct 2024 03:19 PM
My sky glass to keeps saying
please wait for your programme to load
this happens on all channels including recorded playback films etc.
Message posted on 05 Nov 2024 01:19 PM
I think the sky glass/puck looses packets quite often? This is down to a bad Internet connection. I have rebooted my router twice a week and it seems to have cured it (somewhat) I think another problem could be poor software being sent out to the puck? Either way it's a sky problem and they should be addressing it
Message posted on 28 Jan 2025 06:18 PM
What do I do to get programmes to load
Message posted on 28 Jan 2025 06:33 PM
Reboot it bad
or just home button
or 1 channel up the. Go back to the channel needed
Message posted on 28 Jan 2025 06:41 PM
None of those work sadly
Message posted on 11 Jun 2025 02:00 PM
same problem here, nothing wrong with my wifi, as usual sky wash there hands of any problem with their equipment and blame poor internet connection when cleraly there is a fault within their pucks, i have two with the same problem everyday i get this message
Please wait for your programme to load
happens every time within 1-2 hours of resetting them.
shame I can't cancel due not fit for purpose reasons but hey , i will cancel at end of contract.
thanks for posting
Message posted on 11 Jun 2025 02:12 PM - last edited: 11 Jun 2025 02:12 PM
There's no clear evidence that there's anything inherently wrong with the Pucks - for most, they work reliably. Sky are generally amenable to you cancelling mid term without penalty if you're having problems that you've reported and that are unresolved.
Message posted on 11 Jun 2025 03:40 PM
maybe you're right but for both pucks to have problem and my pucks on ethernet seems iffy to me, but thanks for your reply.
my soltuion was to select watch from start, when selecting continue watching.
