Discussion topic: Please I need the sky tech team to come and help me install my sky live stream band
Message posted on 14 Jun 2024 05:15 PM
Message posted on 14 Jun 2024 05:23 PM
Re: Please I need the sky tech team to come and help me install my sky live stream band
@Temitope147 wrote:Please I need the sky tech team to come and help me install my sky live stream band
Sky Stream is self-install only - there are no engineers or 'tech team' to help you.
All you need to do is connect the HDMI cable between the puck and your TV. Connect the puck to the power supply and plug it in. Then select the HDMI input using your TV remote control and follow the on-screen instructions.
Message posted on 14 Jun 2024 05:25 PM
@Temitope147 Did you also order broadband at the same time? If so broadband appointments take at least 10 working days from placing the order to going live, you can check progress within the order tracking section of your sky account or my sky app.
Message posted on 14 Jun 2024 07:16 PM - last edited: 14 Jun 2024 07:22 PM
'live stream band' appears to cover three different products.
'Live' is the camera and associated services for a Glass television set
'Stream' is the online-only Sky TV hardware for use with non-Sky television sets
and '(Broad)band' which is neither of the above, but a separate service from Sky as an ISP (sometimes ordered alongside Glass and/or Stream television)
As @GD1 and @Padam_Padam indicate, there's no installer attendance for the television products. Some broadband service, particularly FTTP, will require an in-premises visit, typically by Openreach rather than Sky personnel.
