Discussion topic: Pixilating telly signal weak or loss
This message was authored by: OapAlan
My telly signal keeps cutting out ever since sky tried to sell glass, why?
Re: Pixilating telly signal weak or loss
I suspect it's a coincidence unless Sky now send out engineers to move your dish out of position if you refuse...
@OapAlan
Are you seeing a “no satellite signal” message? If so check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for OapAlan
This is a sky box via Internet, so no dish perse, I am beginning to thing the router may need a shut down, however this was only done two. Days ago and BBC has been cutting out for a month. But I do appreciate your ideas good sir!
@OapAlan
So if you haven't got Sky Q what have you got as you've posted on the Sky Q board?
Avatar for OapAlan
Internet that is connected via WiFi to a sky box connected to telly, please note I am officially old and unsure what I have got, besides dementia, and a lack of understanding of tech other than basic switch off and on again, with the odd swear word to show the tech how angry I am. I am thinking a factory reset and hope I don't loose the apps which I hope reload when I log it back in again? Thank you for your help and patience for things I have basic understanding of.
@OapAlan
I think you have Stream so I'll move your thread to that board.
Avatar for OapAlan
OK thank you kindly. Good sir. And thank you for your time.
@OapAlan if you open Netflix on the sky box and go to Get Help -> Check Your Network it should give a little report including what download speed the sky box is getting.
This message was authored by: Stephen+Mourton
@OapAlan   We understand your problem with technology and we will do our best to help and happy to be patient.
A couple of things to check, as it sounds like you are connected to your puck via the Wi-Fi rather than a direct Ethernet cable from your router to your puck.  On the basis it is connected over the air via Wi-Fi then does your router have a direct unobstructed view to your puck?  If not try if even temporarily moving things so it has a clear view.  Also check neither router or puck have any objects close to them, plenty of space around them, and check your router is not near a window such as on a window sill or by a mirror.  All these things can effect your connection.
Do you also know your internet speed?  If not we can tell you how to check.  I hope this helps.
