This discussion topic has been answered Discussion topic: Pixelated picture on sky stream
Message posted on 07 May 2026 07:05 AM
I've had my Sky puck for about 3 weeks, first 2 weeks it was fine then one night a horizontal line appeared on the picture & the bottom part of the screen is pixelated. It stayed like that for about 4 days even after several hours of troubleshooting. It randomly started working again for a day & half then back to the same pixelated picture. I spoke to Sky & the suggested a internet cable from the puck to broadband hub, I've done this & it's still not helped. Anyone got any ideas how to fix this issue please?
Message posted on 07 May 2026 09:11 AM
Insist on a hardware swap: if only part of the screen is distorted it's not a bandwidth issue.
Message posted on 07 May 2026 09:28 AM
Re: Pixelated picture on sky stream
@CJA26 wrote:I've had my Sky puck for about 3 weeks, first 2 weeks it was fine then one night a horizontal line appeared on the picture & the bottom part of the screen is pixelated. It stayed like that for about 4 days even after several hours of troubleshooting. It randomly started working again for a day & half then back to the same pixelated picture. I spoke to Sky & the suggested a internet cable from the puck to broadband hub, I've done this & it's still not helped. Anyone got any ideas how to fix this issue please?
Presuming you've done all of the swapping HDMI leads, different ports, different TV or monitor screen then yes, that sounds like a goosed stream puck.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 08 May 2026 03:33 PM
Hi, thanks for your reply. I have spoken to Sky again & they have agreed to send a new puck. Appreciate your response.
Message posted on 08 May 2026 03:35 PM
Thanks for your reply, Sky have agreed to swap the puck. Hopefully that will fix the issue 🤞🏼
