Discussion topic: Picture, sound and freezing problems.
Message posted on 24 Dec 2025 06:44 PM
We frequently lose sound, sometimes the picture freezes and other times the screen goes a blank hey colour.
Message posted on 24 Dec 2025 08:00 PM
Re: Picture, sound and freezing problems.
Resetting the box can help. I have seen a few issues with regard to network connection dropping, but I've never had an issue with picture or buffering etc.
Message posted on 25 Dec 2025 12:03 PM
@Dmc13 This can sometimes happen if your internet speed is poor, do you know what it is? Also if not connected with an Ethernet cable between your router and puck it can also happen. If not connected with an Ethernet cable check your puck is placed away from other objects, not next to them or on top of them, also try and give your router and puck an unobstructed view of each other. Just adjusting your set up in these ways can often solve it
Message posted on 25 Dec 2025 12:37 PM
I have the exact same issue. If I leave it, it sorts itself out after a couple of minutes. Bloody annoying.
