2
This discussion topic has been answered Discussion topic: PIN code removal
This message was authored by: Bobblee
PIN code removal
How can I switch the PIN code requirement off on a stream puck
This message was authored by: mikealanr Answer
Re: PIN code removal
Hi @Bobblee
See: https://www.sky.com/help/articles/your-sky-glass-pin
However note:
"Even if you turn off this setting, you'll still need to enter your PIN if you're watching a Sky Cinema movie or download before its normal watershed time. For example, before 8pm for shows or movies rated 12 or 15, or before 9pm for ones rated 18.
Some shows from Sky Showcase, Sky Atlantic, Sky Comedy, Sky Documentaries, BBC, Channel 4 and E4 might ask for a PIN during the daytime and in the evening if the broadcaster considers the show to be of an adult nature. This is due to Ofcom regulations and can't be turned off."
MikeAlanR
Hi @Bobblee
However note:
MikeAlanR
Avatar for Bobblee
Thank you for replying I will just keep entering the codes 👍
Answered - Go to Answer
