Discussion topic: Not picking up WiFi connection
Message posted on 30 Aug 2025 07:41 PM
Hi I seem to be stuck on this screen now tried everything restarted router puck still nothing as I was asked to factory reset after my uhd problem I now have this problem any ideas thanks
Message posted on 31 Aug 2025 09:07 AM
Re: Not picking up WiFi connection
Who asked you to do a factory reset ?
This should only be done when on the phone with sky and an advisor has talked you through the reset, as when you do a factory reset it wipes all your account details from the puck, i would call sky about this issue
Message posted on 31 Aug 2025 09:39 AM
@Jaydris994 wrote:Hi I seem to be stuck on this screen now tried everything restarted router puck still nothing as I was asked to factory reset after my uhd problem I now have this problem any ideas thanks
Have you tried connecting by pressing the WPS button on your router @Jaydris994 ?
