Discussion topic: Not able to do forgot PIN
This message was authored by: Kelly803
I've got as far as entering and confirming my new pin but it won't go any further
Re: Not able to do forgot PIN
Hi @Kelly803  Unless you have changed your PIN the default is the last 4 numbers of the phone number registered with Sky.
