Discussion topic: No tv guide
This message was authored by Beloved82 This message was authored by: Beloved82
No tv guide
No tv guide.  Last 4 days nothing will play properly without cutting out every 2 minutes.  Says I'm connected to network
Re: No tv guide
@Beloved82  How is your puck connecting to the hub?  What speed are you getting to the puck?  Open the Netflix app on the puck, go to Get Help and run the connection test, what speed is being reported here?
Beloved82
Re: No tv guide
Connect by WiFi and speed test is 18.95mbps
Beloved82
Re: No tv guide
Also thank you for helping! I'm really not sure what has made the tv guide just disappear.  It's just not there as an option at all 😭
Re: No tv guide
@Beloved82  Try a restart by switching off at the wall for around 10 seconds.
The speed you're reporting is well below the minimum the stream pucks need.
Recommended minimum broadband speed of 25Mbps. Or 30Mbps if you add an extra Sky Stream puck or to watch in UHD is what Sky advise.
What is you nromal broadband speed?   Can you connect an ethernet cablke between the puck & hub?  If you do you'll need to go into the setting menu to the network setting and reset the network, you'd also ned to turn wifi off.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: No tv guide
That's likely your problem. The minimum recommended speed for Sky Stream is 25-30 Mbps.
If you haven't tried already you could try and simply unplug the puck for several minutes which may bring back the TV Guide. You will find when the puck's download speed goes below the minimum recommended  it will start to cause issues like this.
The bigger question is why the speed is so low. So do you know what download speed you are expecting to be getting to your property? As part of your contract you should have an estimated and minimum guaranteed speed ( this will help identify if the issue is your actual broadband connection or an issue with your WIFI/home network)
Sky Stream user. Former Sky+ HD and Sky Broadband customer
