Discussion topic: No WiFi connection
This message was authored by: Steve19842
No WiFi connection
I've had sky stream for a couple of weeks. I'm finding it barely usable. Constantly get the No WiFi connection message despite having super fast full fibre and all other streaming services on my TV: Netflix, Disney etc working perfectly. When it does connect it regularly drops out and I get 'technical fault' message.
Is this a fault with the puck?
Re: No WiFi connection
@Steve19842  On on the puck open netflix, go to Get Help, run connection test.
What speed is being reported.
Also it may be worth looking at the network setting in the puck menu and look at the wifi signal indicator.  What is it showing?
This message was authored by: Me123321123
I had loads of issues with the puck, I've reserved 2 IP addresses (one for each MAC address) and that seems to have improved the stability.
A
