Discussion topic: No WiFi connection sky puck
Message posted on 29 Feb 2024 01:57 PM
Sky puck when turning on keeps saying no WiFi connection when there is you have to turn it on and off to keep working
Message posted on 29 Feb 2024 02:04 PM
Re: No WiFi connection sky puck
@Cj29 check to make sure networked standby mode is turned on
“Trying to help improve sky glass”
Go to settings,start up and standby.
Message posted on 29 Feb 2024 02:28 PM
In addition to @Deedee36's suggestion you may also want to turn "overnight powersaving mode" to Off as well.
With both of the settings set like that is should eliminate any potential issues that are occuring when you first turn it out of standby in the morning.
Message posted on 29 Feb 2024 03:36 PM
Thanks for all your replies I will try this
Message posted on 01 Mar 2024 07:39 AM
Well that didn't work 🤦🏻♂️ still came up with no WiFi had to turn it off and on again
Message posted on 01 Mar 2024 08:30 AM
@Cj29 couple of other possiblities, first is your router is set to go into a low power mode and is taking to long to wake up. In which case you can sometimes just wait a few seconds and if you then click Home on the remote the puck will have picked up the connection.
The other is simply the Wifi signal isnt strong enough in which case try moving both the router and the puck so they are out in the open so the signal is maximised however if thst doesnt work you may need to consider a booster or as I did myself invest in a whole home wifi mesh solution.
Message posted on 02 Mar 2024 01:02 PM
The first message that should appear in this situation is.... STARTING INTERNET CONNECTION PLEASE WAIT X MINUTES... then if it fails to connect it should THEN report no Network Connection🤔
Message posted on 18 Sep 2024 07:40 PM
I have the same issue . All other WiFi products fine just the sky puck I centrally have to reset
Message posted on 26 Dec 2024 05:50 PM
I have the same problem with my puck
