Discussion topic: No Atmos from Sky content
Message posted on 06 Apr 2024 05:00 AM
Hi,
I've got a sky stream puck connect to a Harman Kadron Citation 1100 soundbar via HDMI, the soundbar is then connected to to the TV via HDMI arc.
Content through apps such as Netflix and Disney Plus (via the puck) show the Atmos symbol next to content with Atmos and the soundbar confirms that it's playing Atmos content when using these apps.
I have Sky Cinema with the UHD/Atmos package however nothing in Sky Cinema on demand or other on demand sky content (like The Last of Us) mentions anything about Atmos on the film/show information page. It shows that UHD is available so it recognises that I have the UHD/Atmos package.
When I play any sky on demand that I would expect to have Atmos such as recent movies the soundbar shows as just outputting Dolby surround.
I've tried the puck sound settings with both auto and pass through without any success.
Anyone able to offer any advice or guidance?
Message posted on 06 Apr 2024 06:35 AM
							Re: No Atmos from Sky content
https://helpforum.sky.com/t5/Sky-Stream/No-Dolby-Atmos-using-Puck/m-p/4229507
Have a look through this thread.
Message posted on 06 Apr 2024 09:46 AM
Thanks for that. Unfortunately I've tried everything in that thread and it's not made a difference.
I think it's def a problem with the Sky service as I can play Atmos from other sources via the puck without any issues.
Message posted on 06 Apr 2024 10:49 AM
Atmos definitely works on Sky content because my Sony soundbar kicks in to Atmos when it's available. If you have Sky Sports, check one of the games in UHD because they're in Atmos. TNT Sport Ultimate premier league games are normally in Atmos as well.
Message posted on 06 Apr 2024 11:18 AM
No idea with Sky cinema, as do not subscribe to that.
Dolby Atmos works fine on Sky Sports uhd football content.
Try watching the live efl or premier league on the Sky Sports football channels, Sky Sports Main Event UHD or play a live match from the live sports rail at Home>Sports
The uhd F1 on SKY Sports F1 UHD though does not broadcast any Dolby Atmos, as F1 FOM do not supply any Atmos enabled audio broadcasts to Sky.
On demand content in uhd from Sky channels has Dolby Atmos.
Good examples to try are Game of Thrones and House of the Dragon.
All above have worked without issues on my Sky Stream.
Message posted on 07 Apr 2024 08:30 AM
Thanks for the reply guys, unfortunately I still can't get any of the Sky On Demand content to play with Atmos. I don't have sky sports o can't check with that.
I even tried a factory reset with the puck to no avail. Looks like it'll be a phone call to sky tomorrow but not holding my breath that they'll be much help based on other problems with the puck!
Message posted on 07 Apr 2024 09:58 AM - last edited: 07 Apr 2024 10:52 AM
Odd you are getting it via the apps in the puck, so it would rule out any TV or cable problems.
Something to try.
Do a reset, via the below, but important thing is to power off TV and puck (remove puck and TV from power or turn off socket)
Go to Home>Settings and change your Picture & Sound settings to Auto from the Dolby setting..
Put puck and TV in standby, leave off for about ten minutes.
Bring puck out of standby (so still in auto at this point), go back into setting and change the Picture & Sound to the Dolby Digital Plus setting.
Power down the TV and puck as I mentioned above.
The auto function does from what I have noticed a kind of puck sound reset.
Message posted on 07 Apr 2024 10:47 AM
@lettice wrote:Odd you are getting it via the apps in the puck, so it would rule out any TV or cable problems.
Something to try.
Power down the TV as I mentioned above.
Thanks I'll give that a try later and let you know how it gets on.
At what point during the process should I be powering off at the wall? Just at the very end?
Message posted on 07 Apr 2024 10:54 AM - last edited: 07 Apr 2024 10:56 AM
Yes at end for puck and TV.
But do make sure after the auto audio change you do put tv and puck into standby.
Message posted on 08 Apr 2024 11:53 AM
@lettice wrote:
@Spud132 wrote:Thanks I'll give that a try later and let you know how it gets on.
Gave that a try this morning but unfortunately still no Atmos.
Phoned sky and the guy got me to check a couple of things which od already checked myself. He spoke with this tech support department who were unaware of any problems and said it might be a content issue and they'd look into it.
Not going to hold my breath for an answer anytime soon.
Message posted on 09 Apr 2024 01:01 PM
So after lots of resetting and disconnecting and reconnecting over the last couple of days sky content now appears to be playing Atmos where available (yay!).
The only problem I still have is that nowhere on a film/programme information screen does it say whether it's Atmos enabled, and the only way I can find out is by checking the soundbar once it's started playing. Is this the same for everyone? I thought there would have been an atmos logo or something next to the UHD/HDR badges on the information pages.
Message posted on 09 Apr 2024 01:05 PM
@Spud132 wrote:So after lots of resetting and disconnecting and reconnecting over the last couple of days sky content now appears to be playing Atmos where available (yay!).
Atmos has always been a bit of an afterthought with Sky - they don't really shout about it because availability can be so random. Best advice is to not expect it, then treat it as a pleasant surprise when you do get it.
Message posted on 23 Aug 2024 01:29 PM
Hi. I have this exact same problem. Do you know what you did that solved it? Would appreciate it. Thanks
