Discussion topic: New sky stream and broadband customer. Broadband is working, sky tv is not, says technical fault
This message was authored by: Kerrieh1
New sky tv and broadband customer. Broadband is working sky tv is not, says technical fault try later with all channels. I have tried switching off and back on again
Re: New sky stream and broadband customer. Broadband is working, sky tv is not, says technical fault
@Kerrieh1 have yout tried unplugging the stream puck for several minutes, and not just turned it on and off?
This message was authored by: PrincessDiamoni
  • I've tried unplugging it. It's still not working
@PrincessDiamoni How is the puck connecting to the hub?   Have you tried a network reset on the puck?
Have you tried rebooting the hub?
Have you tried ethernet instead?
