Discussion topic: New power cable
This message was authored by: 1986jesa
New power cable
Our pet has just chewed through the power cable for the puck. Where/how would we get a new one? Cheers in advance!
Re: New power cable
@1986jesa  You will need to call Sky as they will need to replace the puck.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Re: New power cable
Nonsense @GD1 the OP simply needs a UK to IEC 60320 C7 Figure of 8 lead: https://tinyurl.com/2apk9suh £4.99 delivered tomorrow.
This message was authored by: Ellie_TV
Re: New power cable
Nonsense. That is NOT the correct power cable for a Sky Stream puck.
This message was authored by: Norman+Mc
Re: New power cable
That's certainly not the plug I have.
