3
This discussion topic has been answered Discussion topic: Need to speak to technical support about Sky stream
This message was authored by: 128Lang
Can someone please supply a contact number that actually works - currently every number i have been given does not connect!
This message was authored by: martswain Answer
Re: Need to speak to technical support about Sky stream
If you have a Sky landline or mobile just dial 150.
Otherwise follow the links from Contact Us at the bottom of this page, if you keep saying you still need help you'll get a number to call.
This message was authored by: Amandacowap2016
Need  to speak  to someone
Go ahead and call.
Or someone here will try to help if you detail why you want to speak to Sky.
