04 May 2024 07:32 PM
I have absolutely no love for sky at the moment. 'Help' is always far at hand.
My sky stream in the second room constructs out.
It does not matter what channel I am watching. The audio and video either bother stop completely or they independently stop withing seconds of eachother.
Either way I am completely missing out on entertainment and the package I am paying for.
Would love to put a video clip on here as instructed in the note above this box but there are no buttons to capture video
04 May 2024 09:37 PM
This sounds like it's the WiFi to your puck. They need a strong and stable connection. Consider connecting via ethernet cable or home plugs and turning off WiFi in the puck settings.
The other option is to get a wireless repeater or mesh system for your WiFi. You would need to speak to your ISP for this and see if they offer it.
MikeAlanR
MikeAlanR
06 Jul 2024 09:33 AM
I have the same issue. I have tried all of the suggestions and still get the same behaviour even over ethernet (powerline).
The main issue here is that I can stream amazon prime and Netflix from the same room over WiFi or Ethernet with no issue
This really points at the network interface of the stream device
I have 150Mbps download speed which is more than enough
If the internet connection were the issue i would see the same with Amazon and Netflix - I don't
06 Jul 2024 09:43 AM
@Parsedave wrote:I have the same issue. I have tried all of the suggestions and still get the same behaviour even over ethernet (powerline).
When connected via Ethernet have you ensured the WiFi is disabled in the network settings?
Once the WiFi is disabled the puck should be rebooted as well.
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
06 Jul 2024 09:46 AM
Yes did all of that
