Discussion topic: My sky puck will not switch on or off
This message was authored by: Keliberry13
My sky puck is stuck on remote control setup screen. The remote won't connect and the puck will not switch on or off using the button underneath but when I disconnect from the mains and switch back on once it loads it goes straight back to the same blue screen but still will not switch on or off using the button
Re: My sky puck will not switch on or off
Follow the recovery procedure exactly as laid out in the recovery step in this Sky help article;
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-...
