Discussion topic: My Puck won’t connect!
Message posted on 11 Aug 2026 06:57 PM
I have just taken delivery of my first Sky router and my devices are all connected, except my Sky Stream Puck!! I've turned it off for an hour, reset the inputs in my tv but it still won't work. It connected and worked fine to my BT router yesterday and then upgraded to a Sky router and it won't work! Typical!
please help
TIA
Nick
Message posted on 11 Aug 2026 07:51 PM
Re: My Puck won’t connect!
Hi @HuggyPhoto
A few things to try. You set you have reset inputs? But have you specifically reset the network and connected it you your new sky router?
https://www.sky.com/help/articles/sky-glass-no-wifi-connection-osm/?irct=help-connect-tv-puck
Above is instructions on resetting the network. Also can you define "not working" where exactly are you getting stuck? Connecting it? Getting up address? Connected but no picture? Technical fault error message etc etc.
MikeAlanR
Message posted on 15 Aug 2026 08:32 PM
Thank you Mike. I have reset and restarted my router and the puck is now working properly. Thank you for your help.
Would you highly recommend the Sky Glass 2nd Gen?
