Discussion topic: Move home with sky stream
Message posted on 03 Sep 2026 11:15 AM
I have moved back to my original address on my account after a five month period in rented accommodation where I was unable to have a sky dish. I want to know if I can simply pick up my sky stream box and it will work in a different house once connected to the internet ?
many thanks
Message posted on 03 Sep 2026 11:49 AM
Re: Move home with sky stream
@Siskystream You'll need to contact Sky to advise them of the home move.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
